A simple stair object is available to add a basic stair representation to the drawing in the Vectorworks Fundamentals, Landmark, and Spotlight workspaces. Vectorworks Architect, Landmark, and Designer products contain a more advanced stair tool for designs that require complex, detailed stairs (see Inserting Stairs).
To insert a simple stair:
● Fundamentals workspace: Wall tool set
● Landmark and Spotlight workspaces: Building Shell tool set
Click to place the object in the drawing, and click again to set the rotation.
