To edit a design layer that is displayed in a viewport:
Select the viewport.
Select Modify > Edit Viewport.
Alternatively, right-click (Windows) or Ctrl-click (Mac) on a viewport, and select Edit from the context menu.
The Edit Viewport dialog box opens. The options available depend on whether the viewport is on a sheet layer or design layer (Vectorworks Design Series required).
Click Design Layer and select the design layer to edit from the list.
Alternatively, right-click (Windows) or Ctrl-click (Mac) on a viewport and select Edit Design Layer or Edit Referenced Design Layer from the context menu to activate the design layer of the right-clicked object (if the right-clicked object does not belong to a design layer, the Edit Viewport dialog box opens).
Select the editing options, and click OK to activate the selected design layer.
If you selected Navigate Back to Viewport, a colored border displays around the drawing window. Edit the design layer objects as needed.
If you selected Display with Clip Cube, switch to an isometric view to see the clip cube. Edit the clip cube to change the extents of the viewport.
Do one of the following when your edits are complete:
● Click Return to Viewport to return to the viewport. This saves changes to drawing objects, but it does not save clip cube edits.
● Press Shift + Esc to exit to the design layer instead of exiting to the viewport. Alternatively, right-click (Windows) or Ctrl-click (Mac) in the drawing area, and select Exit Viewport from the context menu.
● If a clip cube is displayed, right-click (Windows) or Ctrl-click (Mac) the cube face where the section was created; select Update Section Viewport (Vectorworks Design Series required) to save the clip cube edits. Then either click Return to Viewport, or select Exit Viewport from the context menu to exit editing mode.
● If a clip cube is displayed, right-click (Windows) or Ctrl-click (Mac) any vertical cube face other than the one where the section was created; select Create Section Viewport (Vectorworks Design Series required) to create a new section viewport with its section line located at that cube face.
