The group of sub-rows associated with a header row can be sorted and summarized in different ways. These functions can be set independently for each database header row in a worksheet.
The sort and summary functions cannot be used on a header cell for an image column (Vectorworks Design Series required).
To sort or summarize a group of database sub-rows:
If the database header rows are not displayed, select View > Database Headers from the Worksheet menu.
Select the header row of the group of sub-rows to sort or summarize; the header row has a diamond next to its number.
The three icons above the left end of the column header cells become available.
Icon Item |
Description |
Descending Sort
Sorts the database sub-rows in descending order, according to the contents of this column |
Sorts the database sub-rows in ascending order, according to the contents of this column |
Summarize
Summarizes the database sub-rows according to the contents of this column. Sub-rows that have identical items in this column are grouped together in a single row. If a column contains data from a numeric field, the summarized column contains a sum of the values for all objects that are grouped on the row. This may be appropriate for some columns, but not others. For example, you might have a window schedule that sorts and summarizes the data by the Window ID column. You would want the Quantity column to show the sum of all windows with a particular ID, but you would want the Window Height column to show the height of a single window with that ID (not the height of all windows combined). Add an additional summary operator to the Window Height column to show the correct numeric data. |
Click and drag an icon to the column header cell to be used for the sort or summary. A new icon displays next to the column heading letter. For an ascending or descending sort, a number in the icon indicates the sort precedence for that column.
Apply additional sort or summary icons as needed. In each group of sub-rows, up to 20 columns can have either an Ascending or Descending Sort icon, and any number of columns can have a Summarize icon. The Summarize icon can be used on a column by itself, or in conjunction with one of the sort icons.
To remove a sort or summary, click and drag the icon away from the column header cell.
