Use the Material Note tool to annotate the drawing or detail with material composition, and, if desired, scale. Use the Format Text command to edit the text attributes.
To create a material note:
Click the Material Note tool from the Dims/Notes tool set.
Multiple annotation tools share the same position on the tool set in some workspaces. Click and hold the mouse on the visible tool to open the Pop-out Tools list and select the desired tool.
Click to place the object in the drawing, and click again to set the rotation.
