Groove Welding
Symbol
To insert a groove welding symbol:
Click the Welding Sym-Groove tool from the Dims/Notes tool set.
Multiple welding tools share the same position on the tool set. Click and hold the mouse on the visible tool to open the Pop-out Tools list and select the desired tool.
Click to place the object in the drawing, and click again to set the rotation.
Once the object has been placed, its marker can be selected from the Attributes palette (see Marker Attributes).
