Surface Texture Symbol
To insert a surface texture symbol:
Click the Surface Texture Symbol tool from the Dims/Notes tool set.
Multiple annotation tools share the same position on the tool set in some workspaces. Click and hold the mouse on the visible tool to open the Pop-out Tools list and select the desired tool.
Click to place the object in the drawing, and click again to set the rotation.
