DesignSeries00052.pngManaging Saved Settings
If you have saved attributes to use with the Select Similar tool, use the Manage button on the Select Similar Preferences dialog box to rename or delete these saved settings when needed.
To manage saved settings for the Select Similar tool:
  1. Select the Select Similar tool from the Basic tool palette, and then select Preferences on the Tool bar. The Select Similar Preferences dialog box opens.
  2. Click Manage.
  3. The Saved Settings dialog box opens. Select the set of saved attributes to change.
  4. Click OK to close the Saved Settings dialog box. Click OK again to close the Select Similar Preferences dialog box.
Selecting Similar Objects
vectorworks.net
