Vectorworks Cursors
The cursor in the Vectorworks program changes depending on which tool, mode, and modifier keys are currently in use, as well as what type of object the cursor is over in the drawing area. This helps you to know which actions are available at any given time, without shifting your attention from the drawing.
Cursor
Description
2D Polygon tool
Inner Boundary mode is active; click in an enclosed area to create a 2D polygon based on the area’s inner boundary
Reshape tool (2D modes)
Move Polygon Handles mode is active, and the cursor is over a handle; click-click to move the handle
Move Edges Parallel mode is active, and the cursor is over a handle; click-click to move the handle
Change Vertex mode is active, and the cursor is over a vertex handle; click to change the vertex to the type selected in the Tool bar
Add Vertex mode is active, and the cursor is over a handle; click-drag the handle to create a new vertex
Delete Vertex mode is active, and the cursor is over a vertex handle; click to delete the vertex
Rectangular Marquee mode is active, and the cursor is not over any handle
Lasso Marquee mode is active, and the cursor is not over any handle
Polygonal Marquee mode is active, and the cursor is not over any handle
Reshape tool (3D modes)
The cursor is over a handle on a selected 3D object that can be dragged vertically (for example, the top handle of an extrude)
The cursor is over a handle on a selected 3D object that can be dragged in any direction (for example, any handle on a NURBS curve)
The cursor is over a handle on a selected 3D object that can be scaled (for example, a radius handle on a sphere)
Change Vertex mode is active, and the cursor is over a vertex handle; click to change the vertex type
Align Plane tool
Click to define the X and Y axes on the selected object
Angular Dimension tool
Edges mode is active; click two intersecting objects to create the dimension object
Attribute Mapping tool
Click-drag to scale the fill larger or smaller (the cursor is over a corner handle of the mapping object)
Click-drag to rotate the fill (the cursor is over a middle handle of the mapping object)
Click-drag to move the origin of the fill (the cursor is over other parts of the mapping object)
Center Mark tool
Click the highlighted object to create a center mark
Chamfer Edge tool
Select Faces preference off
The cursor highlights edges that can be used in the chamfer operation
Select Faces preference on
The cursor highlights faces that can be used in the chamfer operation
Constraint tools
Click the objects to be constrained
Edit Curtain Wall tool
Click to add a new frame to the curtain wall
Click to split the frames at the frame intersection
Click the second collinear frame to combine the frames
Click to move the frame grid along the curtain wall
Extract tool
Extract Point or
Extract Curve mode
The cursor highlights edges that can be used in the extract operation
Extract Iso-parametric Curve or Extract Surface mode
The cursor highlights faces that can be used in the extract operation
Eyedropper tool
Pick up Attributes mode is active
Apply Attributes mode is active
Fillet Edge tool
The cursor highlights edges that can be used in the fillet operation
The cursor highlights faces that can be used in the fillet operation
Fixed Point Resize tool
Click the point on the selected object that is to remain fixed, and then move the cursor to resize the object
Flyover tool
Click-drag to “fly over” the drawing
Help (What’s This? command)
Click a tool or command to open the online help topic that describes it
Loft Surface tool
The cursor highlights curves that can be used in the loft operation
Move Page tool
Click to move the page print boundary
Pan tool
The Pan tool is active, or the pan mode is activated when another tool is active (Space bar is pressed)
Polyline tool
Bézier Vertex mode
Cubic Vertex mode
Arc Vertex Fillet mode
Power Pack
Edge Selection
Extract tool’s Point and Curve modes, Chamfer Edge tool, and the Fillet Edge tool
Face Selection
Extract tool’s Surface modes, Shell Solid tool, Push/Pull tool, as well as the Chamfer Edge and Fillet Edge tools with the Select Faces option turned on.
Press the Alt key (Windows) or Option key (Mac) to select the back faces of solid objects.
Curve Selection
Loft Surface tool, Project tool, and Push/Pull tool
Surface Selection
Project tool
Project tool
The cursor highlights curves that can be used in the project operation
Push/Pull tool
In Extrude Face or Move Face mode, the cursor highlights faces that can be used in the push/pull operation
Radial Dimension tool
Click the highlighted circle to create a radial dimension
Render Bitmap tool
Click-drag to select the area from which to create a rendered bitmap image
Rotate View tool
Click-drag to rotate the drawing view
Selection tool
Click to scale the selected object
The cursor is over an object; click to select or click-drag to move the object
Click-drag to duplicate the object (the Ctrl key is pressed on Windows, or the Option key is pressed on Mac)
Click to add an object to the current selection (the Shift key is pressed)
Click-drag to duplicate an object (the Ctrl key is pressed on Windows, or the Option key is pressed on Mac)
The cursor is not over any selectable object
The cursor is over edges or points of multiple objects; use either the Coincident Selection key or the Select Coincident Objects command to select the appropriate objects
The cursor is over edges or points of multiple objects, and the Shift key is pressed; use either the Coincident Selection key or the Select Coincident Objects command to select the appropriate objects to add to the selection
The cursor is over edges or points of multiple objects; use either the Coincident Selection key or the Select Coincident Objects command to select the appropriate objects to move
The cursor is over the resizing points of multiple objects; use either the Coincident Selection key or the Select Coincident Objects command to select the appropriate objects to resize
Set Working Plane tool
Click to place the working plane
Click the square center grip and move the cursor to move the working plane
Click a red, green, or blue axis grip and move the cursor to rotate the working plane
Shear tool
Click the point on the selected object that is to remain fixed, and then move the cursor to shear the object
Shell Solid tool
The cursor highlights faces that can be used in the shell solid operation
Symbol Insertion tool
Symbol Pick up mode is active; click a symbol to make it active
Text tool
Click to create a text object
Click to place the text editing cursor in a text object or in a field
Translate View tool
Translates the drawing view from side to side or up and down
In perspective projection, adjusts the distortion by moving the cursor up (more distorted) or down
Trim tool
Click to trim the object under the cursor
Walkthrough tool
Walk mode is active; click-drag to simulate a walkthrough by moving through the drawing
Look Around mode is active; click-drag to change the viewing angle up, down, left, or right
Elevator mode is active; click-drag to move the viewer higher or lower
The cross indicates the control point of the walkthrough
Worksheet object
The cursor is over a worksheet cell
The cursor is over a worksheet column header cell
The cursor is over a worksheet row header cell
Click-drag left or right to change the column width
Click-drag up or down to change the row height
Click-drag left/right to remove/add columns; click-drag up/down to remove/add rows
Click-drag to move the column or row to a new location
Zoom tool
Marquee mode is active; click and move the cursor to create a marquee around the area to zoom in on
Marquee mode is active, and the Alt key (Windows) or Option key (Mac) is pressed; click and move the cursor to create a marquee around the area to zoom out on
Interactive mode is active; click-drag up to zoom in, or click-drag down to zoom out
Context menus
(Mac only)
The control key is pressed while the cursor is over an object or an open area in the drawing; click to open the context menu
All remaining tools
Click to begin the tool operation (such as placing a new drawing object, or splitting an existing object)
vectorworks.net
