Arch00137.pngBolts and Nuts
To insert a bolt and nut (mm or inch):
  1. Click the Bolt and Nut tool from the Detailing tool set.
  2. Click to place the object in the drawing, and click again to set the length and rotation.
Bolts
Inserting Fastener Objects Using the Fastener Tool
vectorworks.net
