DesignSeries00178.pngOffset Links
The offset link connects a roller link and a pin link.
To insert an offset link:
  1. Click the Roller Chain - Offset Link tool from the Machine Components tool set.
  2. Click to place the object in the drawing, and click again to set the rotation.
Linear Roller Chains
Circular Roller Chains
vectorworks.net
