DesignSeries00042.pngRetaining Rings and Washers
Retaining Rings
To insert a retaining ring:
  1. Click the Retaining Ring tool from the Fasteners tool set.
  2. Multiple retaining ring and retaining washer tools share the same position on the tool set. Click and hold the mouse on the visible tool to open the Pop-out Tools list and select the desired tool.
  3. Click to place the object in the drawing, and click again to set the rotation.
Retaining Washers
vectorworks.net
