ShaftsThe Shaft tool allows the creation of a shaft consisting of multiple straight, tapered, and threaded shaft segments.
To insert a shaft segment:
Click the Shaft tool from the Machine Components tool set.
The Shaft tool and Shaft - 3D tool share the same position on the tool set. Click and hold the mouse on the visible tool to open the Pop-out Tools list and select the desired tool.
Click to place the object in the drawing, and click again to set the rotation.
Click the Configuration button from the Object Info palette to add, delete, or modify shaft component segments (see Shaft Segment Properties).
