Worm Gears
To insert a worm gear:
Click the Worm Gear tool from the Machine Components tool set.
Multiple worm and worm gear tools share the same position on the tool set. Click and hold the mouse on the visible tool to open the Pop-out Tools list and select the desired tool.
Click to place the object in the drawing, and click again to set the rotation.
