To insert a bearing lock nut:
Click the Bearing Lock Nut tool from the Machine Components tool set.
The Bearing Lock Nut tool and Bearing Lock Nut - 3D tool share the same position on the tool set. Click and hold the mouse on the visible tool to open the Pop-out Tools list and select the desired tool.
Click to place the object in the drawing, and click again to set the rotation.
