Pillow
Block Bearings
To insert a pillow block bearing:
Click the Pillow Block tool from the Machine Components tool set.
The Pillow Block tool and Pillow Block - 3D tool share the same position on the tool set. Click and hold the mouse on the visible tool to open the Pop-out Tools list and select the desired tool.
Click to place the object in the drawing, and click again to set the rotation.
