Spot00062.pngFormatting Soft Goods Object Labels
A variety of soft goods object labels can be included on the drawing.
To select labels for display and format the text:
  1. Select a soft goods object. From the Object Info palette, click Text Options.
  2. The Text Options dialog box opens.
  3. Specify the text label elements and formatting, and then click OK.
Once the label has been added to the drawing, it can be moved by clicking and dragging the label control point (unless Automatically Position Text is selected in the Text Options). Click Default Text Positions from the Object Info palette of a selected soft goods object to restore the text label to its original location.
Inserting Curtains and Borders
Inserting Pipe-and-Drape Assemblies
Setting Soft Goods 3D Display Options
vectorworks.net
