Inserting
Stage StepsThe Stage Steps tool inserts portable steps typically used with temporary stage structures into a drawing. The type, shape, size, appearance, and presence of railings can be customized.
To insert stage steps:
Click the Stage Steps tool from the Spotlight tool set.
Click to place the object in the drawing, and click again to set the rotation.
Parameter |
Description |
Structure |
Select the style of stage steps; self-adjusting steps have a fixed stringer length and number of steps, and the step rise automatically adjusts to fit the stage height. For the other types of steps, the step parameters are determined according to the selected Create Based On option.
Create Based On |
When steps are not self-adjusting, specifies the method used to determine the step parameters, either by setting stage height and number of steps, or by setting the number of steps and the step rise. Depending on the selection, certain step parameters become available, while the other parameters are calculated for display. ● Stage Height and Number of Steps: Calculates the height of the steps and the rise automatically based on the height of the stage and the specified number of steps ● Number of Steps and Step Rise: Calculates the height of the steps and the stage height based on the specified number of steps and the step rise |
Stage Height |
Sets or displays the height of the stage |
Step Unit Width |
Specifies the width of each step |
Stringer Length (Self-adjusting steps) |
Specifies the length of the stringers for self-adjusting steps |
Stringer Width (self-adjusting and open free-standing steps) |
Sets the width of the stringers for steps with stringers |
Stringer Type (open free-standing steps) |
Select whether the stringers are located inside and under the treads, or outside the treads (the stringer width setting affects the available step area) |
Add’l Stringers (open free-standing steps) |
Adds one or more additional support stringers to the steps, spaced evenly based on step width |
Side Stringer Indent (open free-standing steps, inside stringers only) |
Moves the outer stringers in (underneath the steps) on each side of the stair by the specified distance |
Step Details |
Number of Steps |
Specifies the number of steps |
Add Top Step at Stage Height |
Adds an additional step at the top of the flight, set to the same height as the stage |
Top Step Height |
Displays the height of the top step |
Single Step Rise |
Sets the distance from one step to the next |
Step Thickness |
Specifies the thickness of each step |
Single Step Depth |
Specifies the depth of each step |
Nosing Depth (open free-standing steps) |
Sets the nosing distance (the depth the step protrudes from the stringer) |
Top Color/Texture |
Displays the texture or color selected in the 3D Options |
Trim Color/Texture |
Pitch (Calculated) |
Angle |
Displays the pitch of the stair as an angle |
Ratio (rise:run) |
Displays the pitch of the stair as a rise-over-run ratio |
Percent (Grade) |
Displays the pitch of the stair as a grade percentage |
Leg/Structure Details |
Profile (frame free-standing steps) |
For the Legs-Basic structure type, select a round, square, or octagonal shape |
Color/Texture |
Railing Details |
Show Left/ Show Right |
Select whether to show a railing on the left only, right only, or both sides. Railing parameters apply to both sides. |
Height |
Specifies the height of the top railing |
Add’l Railings (simple, solid free-standing, or open free-standing steps) |
Adds one or more additional railing sets to the steps, spaced evenly based on step width; this parameter is only available when the both left and right railing are selected for display |
Add’l Horiz Bars |
Adds additional horizontal bars to the railing; not available for self-adjusting steps |
Add’l Uprights |
Adds additional upright bars to the railing; not available for self-adjusting steps |
Profile |
Select a round, square, or octagonal railing shape |
Color/Texture |
Draw Arrow |
Select whether to display an arrow in Top/Plan view; the arrow can point up or down. In the Text Options, select the arrow text label to display the word “Up” or “Down” on the drawing. |
Arrow Size |
When drawing an arrow, sets the arrow head size in drawing units |
Specifies the appearance of applicable step elements in 3D views. The 3D Options dialog box opens. For each available portion of the steps, either select the color from the Color list, or select Custom Texture and then select the texture from the Texture list. The Object Info palette displays the color or texture selections in the relevant section. The appearance of Simple stage steps is set from the Attributes palette. |
Set Cart ID |
Enter information about the steps which can be placed on the drawing with Text Options (does not affect the steps’ appearance) |
Note |
Adds a note, which can be placed on the drawing with the Text Options |
Text Options |
Opens the Text Options dialog box, to enable the display and format the text of labels |
Default Text Positions |
Restores text labels to their default positions |
Opens the Classes dialog box, to specify class naming for the various portions of the stage steps. This allows portions of the stage steps to be set to visible, grayed, or invisible. Use the suggested standard class, select a class from the list of classes present in the drawing, or create a new class. Select <Stage Steps Class> to place the stage step element in the same class as the stage steps. ● Class Prefix: Specifies an optional default root class naming standard for all stage step parts; click Use Standard Classes to begin all stage step class names with the prefix, so that they are sorted together. ● Use Standard Classes: Sets the class names for all stage step elements to the default suggested standard names, using the Class Prefix if there is one. ● Stage step elements: For each portion of the stage steps, including the loci that represent the center of the stage step legs for certain Structure types, specifies the class name standard; the class names shown here are applied to the elements. |
Update |
Updates the object when changes have been made to the Object Info palette parameters |
