Spot00055.pngInserting a Stage Deck
The Stage Deck tool inserts rectangular and rounded portable stage structures into a drawing. The type, shape, size, appearance, and presence of railings can be customized. Place several stage decks to create a large stage area.
To insert a stage deck:
  1. Click the Stage Deck tool from the Spotlight tool set.
  2. Click to place the object in the drawing, and click again to set the rotation.
Formatting Stage Labels
Inserting a Stage Plug
Replacing Stage Decks and Trusses with Symbols
vectorworks.net
