Spot00020.pngSetting the High Hook Height
The high hook height of selected hoists can be automatically set to the height of a clicked point. Only selected hoist objects are adjusted by this command (no other drawing objects can be selected).
To set the high hook height of selected hoists:
  1. Switch to a side 3D view, like Left, Right, or Front, that shows the hoists.
  2. Select the hoists to adjust.
  3. Select Spotlight > Hoists > Set Selected High Hook Height.
  4. Click on the reference object, such as the bottom of a support structure, or another hoist. The selected object is highlighted.
The hoists are set to the adjusted High Hook Height.
Setting Hoist Heights
Selecting and Numbering Hoist Objects
vectorworks.net
