Arch00037.pngConductor Sizing Calculator Command
The Conductor Sizing Calculator reports the correct wire size for a given load, based on a single conductor and the length of travel.
To perform conductor sizing calculations:
  1. Select AEC > Electrical > Conductor Sizing Calc.
  2. The Conductor Sizing Calculator dialog box opens.
  3. Select the type of calculation to perform, based on the current parameters, from the Calculate list.
  4. Calculation
    Description
    Wire Size
    Provides the sectional area of the wire (cmil) and the approximate AWG for wire sizes below 250 kcmil
    Ohms/ft/cmil-ft
    Calculates the resistance per sectional area of wire
    Voltage Drop
    Calculates the voltage drop across the length of the conductor, either as a percentage or absolute value
    Phase Factor
    Provides the phase factor value of the conductor
    Voltage
    Calculates the voltage value of the conductor
    Ampacity
    Determines the amp rating of the conductor
    Length of Run
    Calculates the allowable length of the conductor specified for the load given
  5. Enter the required values in the fields. Fields where the result will be displayed appear dimmed. Some calculations require the selection of the wire type or manufacturer, as well as the wire size or part number. When all the required parameter values are complete, the Calculate button becomes available; click to perform the calculation.
  6. The calculation results are displayed. Select another calculation to perform or click Close to exit.
vectorworks.net
