Arch00047.pngCreating Custom Electrical and Communication Symbols
The Vectorworks Architect product includes many pre-defined electrical and communication objects in its object library files. If necessary, you can create custom panel and circuiting symbols instead.
Creating Custom Panels
Electrical, communication, and disconnect panel symbols can be created specifically to fulfill a custom requirement.
To create a panel symbol:
  1. Draw the object to represent the panel.
  2. Select Modify > Create Symbol. Enter a name for the panel and set a destination folder for the symbol as described in Creating Symbol Definitions.
  3. The panel symbol requires both a panel and circuiting record. If the file does not contain panel and circuiting records, create the records shown in the following tables, as described in Creating Record Formats.
  4. Record names, particularly the Type field names, are case sensitive.
    Panel Record
    Field
    Type
    Contents
    Name
    Text
    Must be unique
    Type
    Pop-up
    Must be Electrical, Communication, or Disconnect
    Phase
    Integer
    1
    Volts
    Text
    117
    Amps
    Integer
    100
    # of Spaces
    Integer
    20
    Panel Header Line 1
    Text
    Text placed on Panel Schedule
    Panel Header Line 2
    Text
    Circuiting Record
    Field
    Type
    Contents
    Name
    Text
    None
    Circuit #
    Integer
    0
    Wire Size
    Text
    0
    Trip
    Integer
    0
    Conduit Size
    Text
    1/2
    V.A./Watts
    Integer
    0
    Remarks
    Text
    Panel
    Phase/Pole
    Integer
    2
    Voltage
    Text
    0
    Circuit Type
    Pop-up
    1 for electrical device, 2 for communication device
    UID
    Text
    0
    ID
    Text
    0
  5. From the Resource Manager, right click (Windows) or Ctrl-click (Mac) the symbol, and select Edit 2D Component from the context menu.
  6. In the Edit Symbol window, deselect all symbol components.
  7. From the Data tab of the Object Info palette, click Attach Record. From the Resource Selector, double-click the panel record format to apply it. Select the panel record and enter the panel information in the fields that display below the Detach Record button.
  8. Click Attach Record and attach the circuiting record to the symbol. Select the circuiting record and enter the circuiting information in the data fields that display.
  9. Click Exit Symbol at the top right of the drawing window.
Creating Custom Circuit Symbols
Electrical and communication circuit symbols can be created specifically to fulfill a custom requirement.
To create a circuit symbol:
  1. Draw the object to represent the circuitable symbol.
  2. Select Modify > Create Symbol. Enter a name for the circuitable item and set a destination folder for the symbol as described in Creating Symbol Definitions.
  3. If the file does not contain a circuiting record, create the record shown in the following table, as described in Creating Record Formats.
  4. Field
    Type
    Contents
    Name
    Text
    None
    Circuit #
    Integer
    0
    Wire Size
    Text
    0
    Trip
    Integer
    0
    Conduit Size
    Text
    1/2
    V.A./Watts
    Integer
    0
    Remarks
    Text
    Panel
    Phase/Pole
    Integer
    2
    Voltage
    Text
    0
    Circuit Type
    Pop-up
    UID
    Text
    0
    ID
    Text
    0
  7. From the Data tab of the Object Info palette, click Attach Record. From the Resource Selector, double-click the circuiting record format to apply it. Select the circuiting record and enter the circuiting information in the fields that display below the Detach Record button.
  8. If the symbol requires more than one circuit, create and attach a second identical record named Circuiting Record-1.
vectorworks.net
