Arch00033.pngInserting Switches
The Switch tool inserts an indicator and basic specifications to indicate the type and location of a switch.
To insert a switch:
  1. Click the Switch tool from the MEP tool set.
  2. Do one of the following:
    To use an existing object from the resource libraries, click Active Def on the Tool bar. From the Resource Selector, double-click a resource to activate it. Click on the drawing or wall to place the object, and click again to set the rotation.
    To create a custom plug-in object, click Preferences from the Tool bar. From the Object Properties dialog box, set the default properties and click OK. Click on the drawing or wall to place the object, and click again to set the rotation. The properties can be edited from the Object Info palette.
Electrical and Communication Objects
vectorworks.net
