The Group command groups two or more individual objects (including text and symbols) together. The group of objects is then treated as a single object. For example, grouped objects can be moved to a different layer in one move. In addition, this command can group two or more groups of objects into a single group.
To group objects:
Select the objects (or groups) to be grouped.
Select Modify > Group.
The objects are grouped into one object, and the group is placed in the active class.
