Dual Object Connect
The Dual Object Connect mode trims or extends two objects to connect them at their endpoints or intersections. Only open objects, such as lines and polylines, can be connected. Closed objects, except for NURBS surfaces, cannot be connected.
This mode can also be used to connect roof faces; see Connecting Roof Faces.
To connect two objects:
  1. Click the Connect/Combine tool from the Basic palette, and select Dual Object Connect from the Tool bar.
  2. Click the first, and then the second, object to connect.
The Connect/Combine Options dialog box opens. Select a method for resizing and connecting the two objects.
The two objects are resized to connect to each other.
Connection Type
Example
Mid-Point
Blend
Position Matching
Tangency Matching
Curvature Matching
Connect/Combine Tool
vectorworks.net
