Applying Roof StylesBy a variety of methods, a roof style can be selected for a roof before creating it, or styles can be applied to existing roofs. Once a roof style has been selected for a roof, the Attributes palette is no longer available for changing roof attributes; attributes are set as part of the style.
To apply a roof style prior to creating the roof:
Select the desired roof style from the Style list in the Create Roof or Create Roof Face dialog box. To create an unstyled roof, select <Unstyled> from the list. Create a new roof style by selecting Roof Preferences; see Creating Roof Styles.
To apply a roof style to an existing roof from the Object Info palette:
Select one or more roofs.
From the Object Info palette, select the roof Style. To apply a different (default) style, select Replace.
To apply a roof style to an existing roof from the Resource Manager:
From the Resource Manager, right-click (Windows) or Ctrl-click (Mac) on the resource and select Apply from the context menu. Alternatively, double-click on the resource or drag the resource onto the roof to apply it.
The Roof Replacement dialog box opens. The roof style list is disabled (the style selected in the Resource Manager is applied).
Click OK.
A styled roof can be converted to an unstyled roof.
To remove a roof style:
Select one or more roofs to un-style.
From the Object Info palette Style list, select Convert to Unstyled Roof.
The roof is released from its style; its attributes can be edited from the Attributes palette.
