Creating
a Sheet ListThe Create Sheet List command compiles the current sheet border information for use as a sheet list index or worksheet.
To create a sheet list index:
Select Tools > Reports > Create Sheet List.
The Create Sheet List dialog box opens.
Move the desired title block entries to the proposed sheet list to create the sheet list, and format the list by clicking Format; select whether to create a text object or worksheet from the list.
Click OK.
If the sheet list index is formatted as a text block, click to select the top left and bottom right corners of the sheet list area; the text wraps to fit within this width. If the sheet list index is formatted as a worksheet, click to add the worksheet to the file.
