To insert a ramp:
Click the Ramp tool from the Building Shell tool set.
Do one of the following:
● To use an existing plug-in object resource, click Active Def on the Tool bar. From the Resource Selector, double-click a resource to activate it. Click on the drawing to place the object, and click again to set the rotation.
● To create a custom plug-in object, click on the drawing to place the object, and click again to set the rotation. The first time you use the tool in a file, a properties dialog box opens. Set the default properties, and click OK. The properties can be edited from the Object Info palette.
