ArchLand00025.pngTransferring Stair Properties
Specific stair parameters can be transferred from one stair to another.
To transfer stair attributes:
  1. Click the Stair tool from the Building Shell tool set and select Pick up mode from the Tool bar.
  2. Click Preferences from the Tool bar to set the transfer parameters in the Stair Settings dialog box.
  3. The transfer attributes are not available by clicking Settings from the Object Info palette.
  4. Click the Transfer tab.
  5. Select the attributes to transfer, and select whether the attributes should become Stair tool defaults and/or should also apply to all stairs in the file.
  6. Click OK.
  7. In Pick up mode, click the stair with the desired attributes.
  8. The cursor changes to an eyedropper, and the source stair is highlighted in red.
  9. Move the cursor to the target stair, and click Apply mode from the Tool bar.
  10. Press the Option (Mac) or Ctrl (Windows) key to switch between the Pick up and Apply modes.
  11. Click the target stair to transfer the selected attributes.
Managing Stair Styles
Saving a Stair as a Symbol
Setting Minimum and Maximum Values for Stair Geometry Parameters
Inserting Stairs
vectorworks.net
