Bulb Flat
To create a bulb flat object:
Click the Bulb Flat tool from the Detailing tool set.
The Bulb Flat tool and Bulb Flat - 3D tool share the same position on the tool set. Click and hold the mouse on the visible tool to open the Pop-out Tools list and select the desired tool.
Click to place the object in the drawing, and click again to set the rotation.
