Z-Section
Click the Z-Section tool from the Detailing tool set.
The Z-Section tool and Z-Section - 3D tool share the same position on the tool set. Click and hold the mouse on the visible tool to open the Pop-out Tools list and select the desired tool.
Click to place the object in the drawing, and click again to set the rotation.
