The process of selecting a reflectivity shader is illustrated by the following flow chart.
To import a reflectivity image-based shader:
Select and import the image as described in Selecting the Image for Import.
The Edit Image Reflectivity dialog box opens. Specify the image-based shader properties.
Click OK to import the image and preview the texture.
