When a wall style is deleted, all instances of the style in the current document can be deleted completely or replaced with another existing wall style. Multiple wall styles can be selected and deleted or replaced at the same time.
To delete a wall style:
In the Resource Manager, right-click (Windows) or Ctrl-click (Mac) on the resource, and select Delete from the context menu. Alternatively, select the resource and press the Delete key.
If there are any instances of the wall style currently in the drawing, the Delete Wall Style dialog box opens. Otherwise an alert displays to confirm the deletion.
Click Yes.
If Delete Wall Style Completely is selected, the wall style and all instances of the style are deleted. If Delete and replace Wall Style with is selected, the Wall Replacement dialog box opens automatically.
If walls with different wall styles were selected for replacement, the current wall preview is blank and components are not listed. Wall alignment can only occur for the left, center, or right of the selected walls.
Click OK to replace the wall style of the selected wall.
If you click Cancel, the previous wall style deletion is also canceled.
