 Changing Selected Frame or Panel Settings
Changing Selected Frame or Panel SettingsThe Settings mode changes the settings of either frames or panels that have been selected with the Select Frame or Select Panel mode of the Edit Curtain Wall tool.
To change curtain wall frame or panel settings:
Click the Edit Curtain Wall tool from the Building Shell tool set.
Select the curtain wall to edit.
Using either Select Frame mode or Select Panel mode of the Edit Curtain Wall tool, select the frames or panels to edit.
Click Settings mode from the Tool bar.
Alternatively, right-click (Windows) or Ctrl-click (Mac) on the frame or panel and select Edit Frames or Edit Panels from the context menu.
The Frame Settings or Panel Settings dialog box opens. Change the frame or panel settings as described in Setting Curtain Wall Frame Parameters or Setting Curtain Wall Panel Parameters.
The Frame Settings dialog box, when opened in this way, does not include the frame category selection on the left, since the frames to edit have already been selected.
Click OK.
The frame or panel settings are changed.
