DesignSeries00117.pngCreating Center Line Markers
Use the Center Line Marker tool to indicate the center line on a drawing.
To create a center line marker:
  1. Click the Center Line Marker tool from the Dims/Notes tool set.
  2. Click to place the object in the drawing, and click again to set the rotation.
