Changing a Dimensional Constraint Value
To change a dimensional constraint value:
  1. Select the object with the constraint.
  2. Select Modify > Edit Constraints.
  3. The Edit Constraints dialog box opens.
  4. In the Dimensional Constraint Value field, enter the new dimension, and click OK.
The dimensional value is updated and the object or objects are adjusted.
Editing Parametric Constraints
Deleting Parametric Constraints
Parametric Constraint Errors
