Selecting,
Refreshing, and Converting CablesSeveral cable commands help with quickly selecting cables, refreshing cable data, and converting cables from one type of cable to another or creating a cable from a polyline.
To easily select cables in the drawing:
Select Spotlight > Cables > Select Cables.
The Select Cables dialog box opens.
Click OK. The cables that match the selection criteria are selected.
To update all the cables in the drawing with the values from the Object Info palette, resetting the cable data, select Spotlight > Cables > Refresh All Cables. If cable lengths changed, so that a shorter or longer standard cable length is now required, an informational alert opens.
A polyline or polygon can be converted into a cable, or one kind of cable can be converted into a different kind of cable.
To convert to a cable:
Select the polyline or polygon, or the cable to be converted.
Select Spotlight > Cables > Convert to Cable.
The Convert to Cable dialog box opens.
Click OK to convert the selection to the new cable.
