Creating
HolesBoth 2D and 3D drilled holes are available. The 3D drilled hole is a solid object that can be subtracted from any other solid object to create accurate 3D models of molds, dies, and many other machine parts (see Subtract Solids).
To insert a drilled hole:
Click the desired Hole - Drilled tool from the Detailing tool set.
Multiple drilled and tapped hole tools share the same position on the tool set. Click and hold the mouse on the visible tool to open the Pop-out Tools list and select the desired tool.
Click to place the object in the drawing, and click again to set the rotation.
