J-bolts
Click the J-Bolt tool from the Fasteners tool set.
The J-Bolt tool and J-Bolt - 3D tool share the same position on the tool set. Click and hold the mouse on the visible tool to open the Pop-out Tools list and select the desired tool.
Click to place the object in the drawing, and click again to set the rotation.
