DesignSeries00227.pngKnurled Thumb Nuts
To insert a knurled thumb nut:
  1. Click the Knurled Thumb Nut tool from the Fasteners tool set.
  2. Multiple knurled thumb nut tools share the same position on the tool set. Click and hold the mouse on the visible tool to open the Pop-out Tools list and select the desired tool.
  3. Click to place the object in the drawing, and click again to set the rotation.
Inserting Fastener Objects Using the Fastener Tool
Acorn Nuts
Hex Cap Nuts
Wing Nuts
