Swing Eye Bolts
To insert a swing eye bolt:
Click the Swing Eye Bolt tool from the Fasteners tool set.
Multiple swing bolt and swing eye bolt tools share the same position on the tool set. Click and hold the mouse on the visible tool to open the Pop-out Tools list and select the desired tool.
Click to place the object in the drawing, and click again to set the rotation.
