Marking Object Centers
The Center Mark tool divides an object or object face into quarters, marking the exact center of the object. This tool works for circles, ovals, rectangles, rounded rectangles, and faces of 3D objects that were created by a circular edge. In addition, it can place center marks on the corners of a rounded rectangle.
When the Center Mark tool is active, you can change the dimension standard for new dimensions created in the document from the Tool bar. To do so, select a standard from the Dim Std list, or select Custom Standards to create or manage custom dimensions (see Using Custom Dimension Standards).
Marking the Center of an Object
To mark the center of an object:
  1. Click the Center Mark tool from the Dims/Notes tool set.
  2. Click on the object to mark.
The center is marked by the intersection of two lines.
Marking the Center of a Rounded Rectangle Corner
To place a center mark in the corners of a rounded rectangle:
  2. While pressing Option (Mac) or Alt (Windows), move the cursor over the rounded rectangle corner to mark.
  3. Click to place the center mark.
Editing Dimensions
