Spot00021.pngInserting a Blended Screen and Projector
The blended screen simulates projection screens that require multiple projectors to produce one large image.
To insert a blended screen and projectors:
  1. Click the Blended Screen tool from the Spotlight tool set.
  2. Click to place the object in the drawing, and click again to set the rotation.
The first time you use the tool in a file, a properties dialog box opens. Set the default properties, and click OK.
When you insert a blended screen, a Blended Screen object is created. Once the parameters of the blended screen and projectors have been set, click Insert Projectors from the Object Info palette to create the projectors associated with that screen. The blended screen settings control the initial projector settings, though each projector can then be set independently (by changing parameters like text position or cone display) if needed. Moving or rotating a blended screen after the projectors have been inserted also moves or rotates the associated projectors.
If projectors have already been inserted, clicking Insert Projectors deletes existing projectors and their parameter settings.
The height of the blended screen and associated projectors depends on several factors.
●    The Z value entered from the Object Info palette determines the distance from the active layer plane to the bottom of the screen (including the border).
●    When the screen includes legs, the legs are drawn on the active layer plane unless a Floor Height value has been specified. The Floor Height distance shifts the floor, and therefore the legs, by that amount from the layer plane.
●    Projector stands are inserted relative to both the Vertical Shift and Floor Height values, allowing stands to be shifted up or down from the screen’s floor as set by the Floor Height value.
The blended screen and blended projector object parameters can be edited from the Object Info palette.
Blended Screen Parameters
Blended Projector Parameters
Setting the Image on the Video Screen
Formatting Video Screen Object Labels
Associating Load Objects with a Hanging Position
