Editing
DrainsDrains can be edited and deleted using context menu commands that are available when the Slab Drainage tool is selected.
To edit drain properties:
Select the slab object.
Click the Slab Drainage tool from the Building Shell tool set, and then click Edit mode from the Tool bar.
Right-click on one or more drains and select Edit Drain(s) from the context menu.
The Drain Settings dialog box opens.
Set the properties and click OK.
To delete a drain:
Right-click on one or more drains and select Delete from the context menu.
The drain is deleted.
