Editing Slab StylesFrom the Resource Manager, right-click on the resource, and select Edit from the context menu.
Alternatively, select Edit Style from the Style menu of the Object Info palette, or right-click on the slab and select Edit Slab Style from the context menu.
The Edit Slab Style dialog box opens.
Edit the slab and component parameters as described in Creating Slab Styles.
If a new slab style Name is specified, it replaces the selected slab style name (similar to selecting Rename from the context menu in the Resource Manager).
Click OK.
If slabs with that style already exist in the drawing, the Slab Replacement dialog box opens.
The slab style to apply cannot be selected (the edited style is applied).
Click OK to edit the slab style.
Changes apply to any existing slabs in the drawing with the edited slab style, and will be used for any subsequent slabs created with that slab style.
