Importing Cinema 4D Textures
Cinema 4D textures can be imported for use as a resource in Vectorworks files, even if you do not own a copy of Cinema 4D. The imported textures can be edited from the Edit Texture dialog box (see Editing Textures and Shaders from the Resource Manager).
To import Cinema 4D textures:
  1. Select File > Import > Import Cinema 4D Textures.
  2. The Choose Cinema 4D dialog box opens.
  3. Select the file with the textures to import and click Open.
The Vectorworks software creates a texture resource folder with the same name as the source Cinema 4D file. The textures are placed in the folder, which is accessible from the Resource Manager.
