Importing IGES Format (3D only)
During IGES import:
●    Points are imported as a group of 3D loci.
●    NURBS curves are imported as a group of NURBS curves.
●    NURBS surfaces are imported as a group of NURBS surfaces.
●    Closed solids are imported as a group of imported solids.
●    Open solids are imported as a group of NURBS surfaces.
●    If there is only one element in the IGES file, it is imported as a single element rather than grouped.
Imported solids cannot be ungrouped or edited through the Edit Group command; they can be used in solid operations.
To import an IGES file:
  1. Select File > Import > Import IGES.
  2. The Import IGES File dialog box opens.
  3. Select the file to import, and click Open.
Alternatively, click the file to import and drag it into an open Vectorworks file.
