Importing Rhino 3DM Format (3D only)
During Rhino 3DM import:
●    Points are imported as a group of 3D loci.
●    NURBS curves are imported as a group of NURBS curves.
●    NURBS surfaces are imported as a group of NURBS surfaces.
●    Closed solids are imported as a group of imported solids
●    Open solids are imported as a group of NURBS surfaces.
●    If there is only one element in the Rhino 3DM file, it is imported as a single element rather than grouped.
Imported solids cannot be ungrouped or edited through the Edit Group command; they can be used in solid operations.
To import a Rhino 3DM file:
  1. Select File > Import > Import Rhino 3DM Format (3D only).
  2. The Import Rhino 3DM File dialog box opens.
  3. Select the file to import, and click Open.
