DesignSeries00004.pngImporting a Revit File
Revit files (.rvt or .rfa) created in versions 2011 through 2018 can be imported.
●    All 2D views (floor plans, ceiling plans, and sheets) import as sheet layers, with the graphics inside the annotation group of an empty viewport.
●    The 3D model imports as one or more design layers; a design layer is created for each story of a multi-story model.
●    Revit families import as symbols.
●    For .rfa files, a record is created for the family definition and for every nested family. For .rvt files, a record is created for every family definition.
●    Straight and round walls are imported as Vectorworks walls, with components, and with wall joins preserved. Non-perpendicular walls and walls with horizontal peaks do not import as walls.
●    Windows and doors import as custom window and door symbols, and are properly placed in walls.
●    Floor objects import as slab objects.
To import a Revit file:
  1. Select File > Import > Import Revit.
  2. Select the Revit file to import and click Open.
The RVT/RFA Import Options dialog box opens.
To edit a Revit entity, select it and click Edit Geometry from the Object Info palette.
Object Editing Mode
