The Convert to Group command is typically used for a selected wall (or roof, slab, symbol, or solid) which contains symbols or plug-in objects, like windows and doors, for the purpose of converting the wall and its contained objects into an “exploded” group of either 2D or 3D geometry. If you are in Top/Plan view when converting, you’ll obtain 2D geometry, and if you are in a 3D view when converting, you’ll obtain 3D geometry.
Use caution when converting hybrid symbols. If in Top/Plan view, the 3D component of the symbol may be lost during the conversion. Similarly, in a 3D view, the 2D screen plane portion of the symbol may be lost.
The command also directly converts an extrude, sweep, mesh, or dimension into 2D or 3D geometry or grouped 2D or 3D geometry.
If you have selected a black (or green) symbol instance that was originally created from a plug-in object, the Convert to Plug-in Object command is available instead. The command converts the symbol instance back into a plug-in object which is no longer associated with the symbol definition.
To convert the selected item into grouped geometry, or to turn a symbol instance back into a plug-in object:
In the drawing, select the 3D geometry, dimension, wall, roof, slab, solid, or symbol instance to convert.
Select Modify > Convert > Convert to Group, or, if you had selected a symbol instance that was originally a plug-in object, select Modify > Convert > Convert to Plug-in Object.
If the selection consists of 3D geometry with no contained objects, the selection is converted immediately. If the selected object is a hybrid symbol, or it also contains additional symbols or plug-in objects, the Convert to Group Options dialog box opens.
Click OK.
The result of the conversion is either grouped 2D or 3D geometry, or a plug-in object. To make changes to grouped items, select Modify > Edit Group or Ungroup.
The resulting group can be left as a grouped object or plug-in object or saved as a new symbol.
