Custom Rotation
The center of rotation for this command is limited to the center of the object’s bounding box. The rotation is performed within the screen plane.
To rotate by a custom angle:
  1. Select the object or objects to rotate.
  2. Select Modify > Rotate > Rotate. Alternatively, double-click the Rotate tool.
  3. The Rotate Object dialog box opens.
  4. Enter the rotation angle.
  5. The precision of the values that can be entered (degrees, minutes, and/or seconds) depends on the Units setting.
  6. Click OK.
Rotating Objects
